FYI error on update to 0.10.6
Hi @io_guy
Thought I'd let you know about an error upon update from 0.10.5 to 0.10.6. After the update, nodelink wouldn't start automatically at boot and from a shell I got the following error:
pi@raspberrypi:~/node $ dotnet NodeLink.dll
A fatal error was encountered. The library 'libhostpolicy.so' required to execute the application was not found in '/home/pi/node/'.
Failed to run as a self-contained app. If this should be a framework-dependent app, add the /home/pi/node/NodeLink.runtimeconfig.json file specifying the appropriate framework.
I was able to fix it with the following command:
pi@raspberrypi:~/node $ cp NodeLink.runtimeconfig.json.bak NodeLink.runtimeconfig.json
as it seems NodeLink.runtimeconfig.json wasn't kept/generated following the update.
Here is my dotnet info:
  Version: 3.1.0
  Commit:  157910edee
Edited by beninsteon
