Problem with java ?
dvial_24
Hello,
Sometimes I have some problems with my PLM, I can not communicate with my insteon & x10 devices. But today I have the following messages in my java console :
charger : classe com.universaldevices.client.ui.UDClientApplet.class introuvable.
java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:http://192.168.1.100/com/universaldevices/client/ui/UDClientApplet/class.class
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception : java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
I have reset my PLM, Isy-99i, clear my java, ... but I can not reach the GUI. I did not update or add new programs on my computer.
Thanks, Denis
When you have the Admin Console open via the link I posted select Help | About and see what is listed as My URL. Most of today's routers have a method to assign a static address to a device so it won't change when rebooted.
Or, if using Windows, you can use the link in Network Places which should update when the address on the ISY changes.
Rand
Rand,
It is exactly what I did. I have checked my ip addresses (192.168.1.100 & 74.74.7.4) with my router & in my Network place under windows but I have always this error.
I have cleared my java, closed internet, ... but always the same error.
FYI : WRT54GS, XP, Isy-99i
Denis
Hello Rand,
Please confirm me the time I can call & the region you are, because I am in Québec.
Today I have the same problem with ISY-26. I have re-installed ISY-99i, I can telnet but I have the same problem with IE.
Thanks, Denis
      37.8k
      377.9k
