Setting a notification after a preset time (open door)
I want to set up a pushover notification if I leave my garage door open for 2 minutes.  Sometimes the door sticks and I don't want my cats in the garage.
I'm using my ELK door sensor. I have "If ELK Garage door sensor is violated," but I am stuck there.  How do I write a program to run "If ELK garage door sensor is violated for 2 minutes...."
I have the notifications all set as well.
      Wait 2 minutes
     You're a pushover
If the status changes the timer ether starts over or runs else and cancels the timer process in Then.
Worked out correctly. I was thinking this was the way, but I didn't try it.
The way it's written kind of says I will get an alert 2 minutes later every time the door opens.
Unless the door closes before
