Ecobee not giving me new PIN
NodeLink 0.10.6 Ecobee has stopped working. I restarted NodeLink. Then I clicked "request new 3rd party pin" but it does not appear in the debug log as usual. This appears in the debug log:
2020-10-05 13:15:03 - Ecobee: New tokens received from ecobee.com [ecobee1]
2020-10-05 13:15:03 - Ecobee Web StatusError: InternalServerError [ecobee1]
It's an Ecobee server issue, you need to re-add it with them.  The Polyglot guys are having the same issue.
  • 3 weeks later...
Reboot NodeLink, you should get a pin.  I don't for additional pins on a single program run because Ecobee's shi**y servers like to spit our random errors sometimes and NodeLink would be disconnecting way more if I believed what the servers say.
In the next version I'll add a manual pin request, it looks like Ecobee's servers are worse than ever.
I must have been doing it in the wrong order. I just clicked "request new pin" and then rebooted nodelink and that worked. Thanks so much for your time.
io_guy, when's the next version coming out where I may manually request a pin.  The ns stopped working two days ago, I stopped, started still with no success.  I then removed it, along with the app on the Ecobee site.  Then I readded the ecobee ns, and no pin, instead a lot of error messages dealing with permissions.  It appears the previous ns didn't successfully remove.
Those are Polyglot errors.
Ecobee's servers are a mess right now.  When I remove the app it never works the first time, don't know what they're doing over there.
