Red Exclamation in ISY Admin Console
Hello All, I have started seeing RED exclamation symbols near some of the switches. I am sure it is some error but for what?
I am also having to switch out older switches for "multiple switches set up" ex one end of a hallway. When replacing the failed switch the new one doesn't work or link up. Any help on these two items will be greatly appreciated.
Did you factory reset each device before linking it to ISY?
Did you do a compare of the links found in the devices to what ISY has?
