Questions about Query all and Query at startup
I am running Polyglot and Nodelink on a Rpi4 with ISY994 Ir/Pro with v5.3.0
If Query at startup is checked in the config of the AC does the ISY query Poly and Nodelink? If so what order is the query, Insteon first then either Poly or Nodelink?
I do notice that if the Rpi4 is not running when the ISY is rebooted the ISY start up takes forever but with Rpi running first then ISY rebooted start up is a lot quicker.
For those of you running Rpi and ISY what is your method of reboot after a power failure. Do you have your Rpi boot up first then ISY or concurrently? Do you have the Query at startup selected or do you have a program that runs after reboot to do the query?
-Tim
