Motion sensor Disable
I have a motion sensor that triggers a light on. If I disable the sensor, it still triggers and the light goes on.
As a temporary work around, I set the On Level to off.
The sensor is in a scene with a light switch and nothing else.
Am I looking at this wrong? I'm assuming disable will ignore the trigger.
I don't know if this is a version issue. Updated to 5.3 yesterday.
Sensor: 2842-222 v.44
My wife does not want the porch lights to go on for Halloween :-)
To many bulbs to unscrew.
The scene works completely outside of ISY (once you set it up).  So disabling the sensor in the ISY admin console really doesn't do anything to the scene operation.
You could pull the air gap on the switch.  Or delete/adjust the scene as you have done.
