Posted October 30, 200717 yr I'm trying to get my ISY set up, and am having some PLM problems that we are working through. But I also am starting to see a strange phenomenon with the ISY control. FYI, I'm running 2.4.12. What happens is as follows: if I close the ISY GUI after having several "Cannot Communicate...." errors (due to what we think are PLM issues), sometimes when I go back into the GUI, I find that a dimmer or lamplinc has had the "On" value magically change to "0%", instead of where I left it at "100%". Likewise, when going back into the GUI I sometimes find that the ramp rate has magically changed from 0.1 seconds to 9 minutes. In none of these case had I ever actually changed the values. I was just toggling on or off, or querying the device. After getting failure messages, I would close the ISY GUI, and the browser window. And then when restarting the application, these errors would appear. Maybe only 10% of the time. Has anyone else seen this?? Thanks
October 30, 200717 yr I am not sure about this one but here is my thought; that the device may have some old settings the system is picking up on. Maybe doing device soft reset (pull the set button out 10 sec, push in and hold 5 sec) might help. Then go back to the ISY and right click on that device and do the "Restore Device". After that see if it still happens. Again I am not sure about this answer but it won't hurt to try it.
October 30, 200717 yr Author I am not sure about this one but here is my thought; that the device may have some old settings the system is picking up on. Maybe doing device soft reset (pull the set button out 10 sec, push in and hold 5 sec) might help. Then go back to the ISY and right click on that device and do the "Restore Device". After that see if it still happens. Again I am not sure about this answer but it won't hurt to try it. Hello Mark: Been there already. I have already factory reset all of the devices, and removed links to all other devices. This seems to only happen infrequently, but when it does, a communication error failure has usually occured prior to closing the GUI. That's why I wonder if the problem is with the way that the ISY application closes after an error occurs. Best regards, Best wishes
October 30, 200717 yr Yeah you’re back to the communication error then. When the ISY puts up that error message it has no way to guess the level then, so it’s just giving you inaccurate info. When you get the communication issues figured out all your problems will greatly minimize.
