andrew77 Posted November 18, 2020 Posted November 18, 2020 After having to unhook a switchlink (for renovations) I've found its acting odd. Once in a while when I press the load button on the KPL it shares the switch box with the SWL will dim down quickly and brighten back to its original state. Its V.27 and I'm pretty sure its older. Does it sound like its on its way out? Related stupid question, Although the electrician is competent he wasn't familiar with Insteon stuff. I mentioned the red is load and black is line and he was fine with that explanation (He heard of Insteon just never used it before) I haven't opened the box to check but I'm assuming if he got it wrong it would not work at all, correct? I only ask as I've never seen this odd SWL behaviour before. Drew
Brian H Posted November 18, 2020 Posted November 18, 2020 With the power off. As you don't want any unwanted surprises. You may want to verify the AC power and Load wiring is connected securely and correct.
