Door lock suggestions?
Hi,
About 5 years ago, I installed a MiLocks door lock kit. Since I was busy with home improvements, I did not immediately install the required add-on gadget to control it with ISY... By the time I wanted to do so, it was not available anymore. Now, only 5 years after the installation, some buttons need to be pushed way too hard to work and the system is not reliable anymore.
So, time has passed, now we have Google Home integrated with the ISY944 and many insteon devices. I would really appreciate if anyone could recommend a door lock kit that would be reliable and easy to control and integrate with the hardware that we have.
Any suggestions of set up that you have and that satisfies you?
I join a picture of the actual kit I have, since I will need the same type of hardware to replace it.
Thank you!
