Bob Chase Posted December 10, 2020 Share Posted December 10, 2020 Searched the forum and didn't see this exact issue listed. When I try to load the program using the "ISY994 Administrative Console" shortcut, I get a pop-up box that says "unable to launch application". If I repeatedly double-click on the shortcut, on the fifth double-click, I get a pop-up that says "downloading application" and then it fails to load. On the sixth double-click the program usually loads normally although very occasionally I have to load the saved local ISY address in the finder box too. I'm running v4.8.0 software and firmware, loaded in June. I've tried clearing the Java cache, adding the ISY website, adding the local ISY IP address, completely deleting Java and reloading. I'm really confused as to why Java is complaining about the certificates not matching on a .jnlp file it just downloaded. Happy Trails, Bob Link to comment
Techman Posted December 10, 2020 Share Posted December 10, 2020 What operating system are you running When you cleared your java cache did you check all 3 boxes? Did you download the ISY launcher from here: Release 4.8.0 Is Now Official - Current Release, Betas, and Bug Reports - Universal Devices Forum (universal-devices.com) 1 Link to comment
Bob Chase Posted December 11, 2020 Author Share Posted December 11, 2020 @Techman Yes, I cleared everything - multiple times. However, I downloaded the launcher from an ISY email. Later, I would download from a saved address from the Wiki: http://isy.universal-devices.com/994i/admin.jnlp The new new Java download from your referenced link says "start.jnlp" and has a different launch behavior. It also puts a different icon onto the desktop. Strange that the old link would still be valid. Thanks very much for your help. Happy Trails, Link to comment
