Scene turns on Lamplink that is not in the scene
Hi,
I have a morning wakeup scene that turns on a lamp (lamplink) next to me but it also turns on a second lamplink in the same room which happens to be on the same circuit, this second lamplink is not in the scene. I can't get it to do this when manually activating the scene.
I reset the lamplink that should not be in the scene. Not sure where to go from here.
Thank you,
Wayne
Hello Wwat,
I've just hunted few ghost link myself :-)
Here are 2 suggestions :
1-Do a "Device Restore" on the lamplinc that turns On when it should not.
If it still turns On...
2-Add the lamplinc in that scene and once done, remove it.
It it still turns On when it should not...
3-Re-do the No1
If it still turns On when it should not...
Well, give us more details about your settings :
Are you using programs for triggering that scene ? (I guess you do because it is a morning wake up scene...) If you are, please post a copy of it.
Is there another controller than the PLM in that scene ? If there is one, do the "Restore Device" on it too.
Hope the first ideas will do the job,
JacquesB
