marcin Posted January 6, 2021 Share Posted January 6, 2021 I was wondering if anyone connected the COSMO-4W or COSMO-2W Smoke and CO sensors via i4 Interface Module to their ELK system. https://www.systemsensor.com/en-us/Pages/COSMO-4W.aspx Quote Link to comment Share on other sites More sharing options...
TrojanHorse Posted January 11, 2021 Share Posted January 11, 2021 I was wondering if anyone connected the COSMO-4W or COSMO-2W Smoke and CO sensors via i4 Interface Module to their ELK system. https://www.systemsensor.com/en-us/Pages/COSMO-4W.aspx Yes. I am using the 2 wire detectors and the interface and it works well. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
marcin Posted January 11, 2021 Author Share Posted January 11, 2021 Thank you. How did you hook up the controller to the Elk? Quote Link to comment Share on other sites More sharing options...
TrojanHorse Posted January 15, 2021 Share Posted January 15, 2021 Thank you. How did you hook up the controller to the Elk?Well the basic idea is you have the detectors in a loop that connect to the module. The module then connects to the panel zones. You add a smoke zone, CO zone and non alarm maintenance zones. Power for the module comes from SAUX. You may need EOL resistors, I can’t remember Hopefully that helps you make sense of what you’re seeing in the schematic wiring instructions. A good way to attach the module is with I believe a 4 inch square metal box with an offset nipple to the Elk can. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Join the conversation
