Unable to sync UD Mobile
Downloaded UD Mobile from Play store. Got it to recognize my ISY and set up both remote and local access successfully.
However, when I try to save the system settings and allow the sync to run, I got a Java error and the process hangs.
Error: java.lang. NullPointerException:NLS CMDP object requires a p_id
FYI: ISY is running 5.3.0 and I restarted before I installed UD Mobile.
Also, I have one node running on a local polyglot server (Hue Server). The error seems to happen when syncing that node.
Is there a setting or something I need to change/set on either the ISY to get this to work.
Edited by DVaslow
added info
  • 1 month later...
Embarassingly, I hadn't noticed that my ISY Remote subscription had lapsed. To be fair, the expired notice was buried a bit, but after renewing the subscription everything worked just fine.
J
