Can't access Admin console after Java update
I'm embarrassed to ask this question since I've seen it posted numerous times in the past.  I just updated Java and can no longer access my admin console.  Help!
Clear the Java cache, and then follow the instructions in the thread linked below to use The Launcher.   The Launcher is the newer method of accessing the admin console that always gets the correct version to match your firmware.
One thing that bit me was not putting the memory expansion back into Java after I had updated Java.  Without that I cannot load programs in the admin console at all.
  • If the admin console is slow to respond, it is likely you need to increase the amount of memory allocated to the Java runtime (JRE).
  • Open the Java Control Panel, select Java tab, press View button, then add or modify the Runtime Parameter -Xmx to the following:
    • -Xmx512m
  • Press Ok to close the window, then Press Apply to save the changes
