Node Name - MUST BE A STRING
I tried to setup the UD mobile app but when I try to sync and save I get the following error message.
Error: java.lang.illegalArgumentException. Devices - Node Name - MUST BE A STRING
Any insight ... what can I try?
Hi @bikerbobhain,
Do you have any nodes,folders,programs, or variables without a name? I assumed that all of theses items had names, so there is an error check to verify a name is not empty. We may have to change this as it appears from you error this is not the case.
I'm not sure what happened but I ran z-wave synchronize nodes and repair links.  After that it looks like I now have Devices and Scenes and My Programs.  Variables both Integer and State are still missing.  So I don't really know what is going on here but it look like progress.  I'm still working on the variables.
Good job ... careful inspection revealed a directory without a name.  Things now synchronize and I have Variables too.
Please accept my apologies.  I did not understand what the error message was pointing me to.  I did support work for a while and I try to resolve things on my own if possible.
Thanks and Apologies
