GeoFence program
Hello
Sorry, but I cannot properly configure a simple program.
I created an occupancy node that works great with the locative app. When I'm home it say “in” and when I'm outside it say “out”.
Now, how in a program that involves the status of this node, can I trigger it only when the status is changing from out to in and then for example turn on a light outside at sunset?
The following program turns the light on even though I am at home.
Should I use a program with variables ?
Help please
Thank you ..
Jack
          'home' Occupied is True
And   From    Sunset  - 15 minutes
          To      Sunrise + 15 minutes (next day)
        Set 'Light Garage' On
        Wait  30 minutes
        Set 'Light Garage' Off
   - No Actions - (To add one, press
Assuming that I understand what it is that you are trying to accomplish, I would tackle this problem with two programs...
first program:
if
occupied is true
then
run second program (if path)
second program (should be disabled):
if
time is from sunrise
to sunset (next day)
then
turn on garage lights
wait 30 minutes
turn off garage lights
40 minutes ago, jacmath said:
I do similar, but ignore time-of-day. Just run the lights for 30 minutes.
What I want precisely is when I arrive in a radius close to the house that the garage light comes on after the sunset for a period of 30 minutes. The radius is already managed by the Locative app.
Jack
Jack
I understand that you want the garage lights to come on only as you transition the radius boundary, and only during certain times of the day (sunset-to-sunrise).  That was my assumption.  Thanks.
My suggested approach stands.
@jacmathYou must use the two program approach that @oberkc suggests.   If the single program that you suggest in the first post is used the lights will also turn on for 30 minutes at sunset if you are home at that time.  The two program approach says "if the first then happens, then run a second program and check some more conditions."
and I just ran the programs you suggested to me and everything is working wonderfully
thank you again
Jack
Edited by jacmath
