I have a scene that includes a homeseer dimmer switch (HS-WD200+) and a homeseer switch (HS-WS200+).  The HS-WD200+ is the controller and the HS-WS200+ is a responder.
If both devices are on / scene on, when I press the paddle to turn the HS-WD200+ off, the HS-WS200+ turns off - expected behavior
If both devices are off / scene off, when I press the paddle to turn the HS-WD200+ on, the HS-WS200+ doesn't respond / stays off - Any thoughts what's going on?  Cannot figure it out.  The ISY 'sees'  both the On and Off paddle presses of the HS-WD200+ but the HS-WS200+ just doesnt respond to it.  Is my HS-WS200+ and I should just replace it?
I can control the scene on/off and devices directly from the ISY Console with no issue, but local on taps don't trigger the scene / HS-WS200+ on.
Do I just need to replace the HS-WS200+?
