Cannot update 2477D On Level
Issue – Cannot update On Level of Insteon 2477D v45
·       Logged into Admin Console (Cloud)
·       Can turn Insteon Device ON/OFF
·       Set On Level to 100% from current level of 40%
·       Click ‘Write Changes’ – ‘Ready’ indicator in lower left corner flashes briefly
·       File -->Refresh Device Status = On Level 40%
Current Status
System Status
Active
Yes
Total
3956 MB
Reserved
395 MB
Used
10 MB
Bad
0 B
Free
3550 MB
About
Firmware
Insteon_UD994 v.5.3.0
UI
Product
ISY 994i/IR PRO (1110)
OpenADR (21010)
Z-Wave (21100)
Portal Integration – UDI (21075)
PLM Info/Status
XX.XX.XX v9E / Connected
Thanks for any help.
It's not intuitive:
Set the dropdown on the RIGHT, then move back to the left and PUSH the button to the LEFT of the dropdown that you adjusted.   (write changes is not needed).   Specifically press the Label box for the dropdown: On, Beep, On Level, Ramp Rate, Backlight.
Additionally there is a GUI bug with "Backlight", after you set it, and press "backlight" the change will be written to the device as expected.  When you move to the next device the "backlight"  dropedown will be prefilled with whatever you set the last device to, it doesn't reflect the value actually stored in the device.  When the admin console is restarted it will say 0% again for backlight.   None of this effects the actual backlight setting in the device, its just the admin console display.    To rephrase, the backlight value can be set from the admin console, but the value displayed in the admin console is false.
Edited by MrBill
Thank you Mr. Bill for the quick reply.
The current On Level is 40%. I set the On Level to 100% in the drop down and click the 'On Level' button to the left of the drop down, and the On Level in the drop down returns to 40% - no change.
Ghosts in the machine?
This must be something with the insteon device. I tried the process on another insteon switch with success. I will pursue working on the insteon switch.
It appears the the Admin Console is working properly.
Thanks again
Glad you got it working on another device.   As for the one with the issue, you could open the Event Viewer and set it to level 3 and compare what you see between the one that works vs the one that doesn't.  Or if you need interpretation post the event viewer log in the forum, and someone will point out what might be happening (probably not me, I'm not good with interpreting the event viewer).
Thank you Larryllix.
Interesting - When I set the on level manually at the switch to 100% it works. Thereafter when I turn on the switch from the Admin Console, it turns on to 40% (the incorrect setting in the AC). Thereafter, when I turn on the light at the switch, the On Level is 40%. It appears the AC is rewriting the incorrect On Level when an ON command is sent from the AC.
Thanks Mr. Bill
Attached are the device addresses to help with reading the event file and the event file. To recap: From the Cloud Administrative Console device 51 81 6B the On Level change command to 100% seems to revert to 40% when the button is pressed.
On device 50 82 8E - the same command is successful in changing the On Level to 100% from 40%
Can anyone tell from the event log what the problem might be?
ISY_About20210625.pdf ISY-Events-Log.v5.3.0__Mon 2021.07.12 10.58.25 AM.txt
As mentioned other people are going to be better at reading the events log than I am.
One thing I note however... you have mismatched firmware and UI,  The firmware is 5.0.16C while the UI is 5.0.16.  This needs to be corrected and then you should retest.  To be clear, both firmware and UI should be 5.0.16C.
The best way to start the admin console is to use The Launcher (Launcher is different than Finder, people seem to confuse that point.) Launcher always matches the correct version of the admin console with the version of the UI being used.   See the thread linked below for how to install Launcher, Launcher does require an internet connection (or actually maybe the latest version doesn't require internet connection... I'm not 100% certain on that point--there was a recent change--launcher is still the best way tho).    If you still prefer you can still download and start admin.jnlp directly from the ISY, but if you want to continue using this method please delete you copy of admin.jnlp and clear your java cache then get the new admin.jnlp from your ISY.
Thanks Mr. Bill.
Both the firmware and admin console are 5.3.0.
Same result on attempted change of On Level.
UPDATE - SOLVED
Self inflicted problem.
I had a program that would set the on level to 40% if the on level was > 40%. So, each time I attempted to set the on level to 100%, the program would run the 'then' section and reset the on level to 40%.
Total newbie error. Sorry for taking the forum's time.
1 hour ago, SESamuels said:
UPDATE - SOLVED
LOL! Most of us have been caught on those previous ideas we forgot about from years back. Shows the automation engine works well though.
Glad you found it!!
