Program Event Times Incorrect-ISY Polisy
@Javi,
I recently connected ISY/Polisy to UD Mobile and I notice the program event times are off by 5 hours. For example, a program start time that should be 11pm is actually shown as 6pm. The times are correct in the Admin Console. My time zone is set to Austin, TX.
UD Mobile displays the correct times for my other system, an ISY-994i.
@Javi,
The issue may be related to converting from 24 hour format to 12 hour format.
All 3 program times have incorrect values and they are initially incorrect.  My times are shown in 12 hour format with exceptions.
While looking at my test program in UD Mobile, I changed to the start time in the Admin Console and the Next Scheduled Time immediately change to the new time, but was off by 5 hours.  It was in 12 hour format.  When the program started, the Last Run Time and Last Finish Time changed to 24 hour format and were correct.  I let the program finish and the Last Run Time and Last Finish Time were as expected and still in 24 hour format.  But when I backed out of the program screen and went back in, the times had changed to 12 hour format and were 5 hours off.
Hope this helps.
Mark
58 minutes ago, Javi said:
@mbking,
Are you running the most recent build for Polisy?
@Javi,
As far as I know, yes.  I had one update available last night which upgraded ISY from 5.0.4-6 to 5.0.4-8.  FreeBSD Polisy 13.0-RELEASE-p3.
Edited by mbking
1 hour ago, mbking said:
@Javi,
Thanks. We found a firmware issue with REST requests for programs, let us know if its not corrected within the next couple of versions.
Will do!
This issue has been corrected in the most recent update to Polisy.  Great work!
Mark
