Backup solution
Hi,
I'm trying to figure out how to have an easy plug and play backup solution for the isy994i ZW. I just replaced a unit and there were a lot of steps to transfer the ZWave network devices.
Is there a way to have a second controller already on the network and connected to the devices? Even if it was not connected but prepared in advance, then I could just physically swap the units without having to redo zwave devices.
1 hour ago, toast said:
Hi,
No there is not. Zwave doesn't work like that. Even if there was, you'd be spending more time trying to avoid the issue than it would take making a back up and restoring
Thank you. Appreciate the help.
