ISY Upgrade from 4.x to 5.3.2 = flashing insteon light?
Hi,
I upgraded from a 4.x version of the ISY to the 5.3.2 so I can use the ISY app on my phone.  I have a light dual band switchlinc on/off version 45 & I dont know why but it is in a never ending loop of on/off over & over.
I am a bit confused - i can turn it on & off with the java program & of course it will just continue its on / off routine.
Any ideas what I can do to fix this?
Rich
try disabling the switch by pulling out the set button then. take a look at any programs that include the switch as they may have been modified when you upgraded your firmware causing the program to enter a loop.
Also make sure that your firmware and UI are the same version.
How fast is the light cycling on/off?
Open the event viewer and set level 3?  do you see the on/off cycle there?
Also open the Programs Tab > Summary Tab and click the Activity Column header to sort by that column, review what programs are running.
Also, I doubt it has any effect on the stated issue, but why did you pick 5.3.2?  why not 5.3.4?
Hi - I picked 5.3.2 for no particular reason but figured it was old enough to be stable.
The level 3 info says (just a few seconds).
Sun 08/29/2021 09:26:48 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 27 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:48 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 08/29/2021 09:26:49 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:49 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:49 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:49 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:49 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:49 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:49 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:49 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:49 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:49 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:49 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:49 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:50 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:50 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:51 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:51 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:51 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:51 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:51 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:51 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:51 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:51 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:51 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:51 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:51 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:51 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:51 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:52 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:52 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:52 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 27 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:52 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 08/29/2021 09:26:52 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:52 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:52 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:52 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:53 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:53 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:53 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 27 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:53 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 08/29/2021 09:26:53 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:53 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:53 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:53 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:54 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:54 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:54 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 27 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:54 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 08/29/2021 09:26:54 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:54 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:54 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:54 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:54 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:54 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:55 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:55 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:55 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:55 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:55 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:55 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:55 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:55 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:56 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:56 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:56 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:56 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:56 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:56 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:56 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:56 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:56 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:56 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:56 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:56 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:56 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:57 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:57 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:57 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:57 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:57 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:57 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:57 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:57 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Sun 08/29/2021 09:26:58 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 11 FF
Sun 08/29/2021 09:26:58 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 11 FF 06          LTONRR (FF)
Sun 08/29/2021 09:26:58 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 11 FF    LTONRR (FF)
Sun 08/29/2021 09:26:58 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:58 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [255] uom=100 prec=0
Sun 08/29/2021 09:26:58 PM : [  46 D9 B2 1]       ST 255 (uom=100 prec=0)
Sun 08/29/2021 09:26:58 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=255 Condition=0 prec=0
Sun 08/29/2021 09:26:58 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=255 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Sun 08/29/2021 09:26:58 PM : [INST-TX-I1  ] 02 62 46 D9 B2 0F 13 00
Sun 08/29/2021 09:26:58 PM : [INST-ACK    ] 02 62 46.D9.B2 0F 13 00 06          LTOFFRR(00)
Sun 08/29/2021 09:26:59 PM : [INST-SRX    ] 02 50 46.D9.B2 48.EA.41 2B 13 00    LTOFFRR(00)
Sun 08/29/2021 09:26:59 PM : [Std-Direct Ack] 46.D9.B2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 08/29/2021 09:26:59 PM : [D2D EVENT   ] Event [46 D9 B2 1] [ST] [0] uom=100 prec=0
Sun 08/29/2021 09:26:59 PM : [  46 D9 B2 1]       ST   0 (uom=100 prec=0)
Sun 08/29/2021 09:26:59 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST Converted values Event=0 Condition=0 prec=0
Sun 08/29/2021 09:26:59 PM : [D2D-CMP 00D4] STS [46 D9 B2 1] ST op=1 Event(val=0 uom=100 prec=0) is Condition(val=0 uom=51 prec=0) --> true
Thanks - the program was on some sort of loop - I didnt even remember making it but I am good to go again!
Glad you found it!
I'd recommend installing 5.3.4... it hasn't shown any instability.
Second the ISY v5.3.4. It fixed a lot of small quirks.
