apostolakisl Posted September 13, 2021 Share Posted September 13, 2021 I have had the node server for a while. I have an I7 Roomba. The thing won't stay connected. After a restart of the NS or even a full reboot of Polisy, it connects and works. A few hours later, it is done. No connection. It used to stay connected for a good long time, but even then I found a periodic restart was needed. But now, it is ridiculous. Anybody else having issues or successes here? Link to comment Share on other sites More sharing options...
fahrer16 Posted September 14, 2021 Share Posted September 14, 2021 Any logs or anything else to help diagnose the issue? Link to comment Share on other sites More sharing options...
apostolakisl Posted September 14, 2021 Author Share Posted September 14, 2021 14 hours ago, fahrer16 said: Any logs or anything else to help diagnose the issue? This is after rebooting polisy this morning. Those errors messages just keep on rolling on and on. 2021-09-14 09:04:07,762 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-09-14 09:04:11,985 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-09-14 09:04:11,987 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-09-14 09:04:12,098 MainThread py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:32: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working 2021-09-14 09:04:12,098 MainThread py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:32: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working 2021-09-14 09:04:12,210 MainThread polyinterface DEBUG polyinterface:write: CV or numpy module not found, falling back to PIL 2021-09-14 09:04:12,213 MainThread polyinterface DEBUG polyinterface:write: PIL module not found, maps are disabled 2021-09-14 09:04:12,288 MainThread py.warnings WARNING warnings:_showwarnmsg: ./roomba-poly.py:15: ResourceWarning: unclosed file <_io.TextIOWrapper name='server.json' mode='r' encoding='UTF-8'> 2021-09-14 09:04:12,288 MainThread py.warnings WARNING warnings:_showwarnmsg: ./roomba-poly.py:15: ResourceWarning: unclosed file <_io.TextIOWrapper name='server.json' mode='r' encoding='UTF-8'> 2021-09-14 09:04:12,309 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.1.1', 'igb0')}, 2: [('192.168.1.1', 'igb0', True)]} 2021-09-14 09:04:12,310 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.1.1', 'igb0') 2021-09-14 09:04:12,311 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.1.178', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}] 2021-09-14 09:04:12,367 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.1.178', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2021-09-14 09:04:12,565 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-09-14 09:04:12,772 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-09-14 09:04:12,774 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/15 - MID: 1 Result: 0 2021-09-14 09:04:12,775 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-09-14 09:04:12,776 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-09-14 09:04:12,784 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-09-14 09:04:12,792 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-09-14 09:04:12,987 NodeServer polyinterface INFO roomba-poly:start: Starting Roomba Polyglot v2 NodeServer version 1.1.4 2021-09-14 09:04:12,990 NodeServer polyinterface DEBUG roomba-poly:discover: Beginning Discovery on Roomba Bridge 2021-09-14 09:04:12,991 NodeServer polyinterface DEBUG roomba-poly:discover: Connecting to Roomba 2021-09-14 09:04:13,024 NodeServer py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:340: DeprecationWarning: The 'warn' method is deprecated, use 'warning' instead 2021-09-14 09:04:13,024 NodeServer py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:340: DeprecationWarning: The 'warn' method is deprecated, use 'warning' instead 2021-09-14 09:04:13,026 NodeServer roomba.__main__ WARNING roomba:setup_client: TLS Setting failed - trying 1.3 version 2021-09-14 09:04:14,199 NodeServer polyinterface INFO roomba-poly:discover: 1 Roomba's identified in configuration 2021-09-14 09:04:14,281 NodeServer polyinterface DEBUG roomba-poly:_startRoombaConnectionDelayTimer: Starting roomba connection delay timer for 5 seconds 2021-09-14 09:04:19,297 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Attempting to add 1 roombas that have connected 2021-09-14 09:04:19,298 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Processing Roomba (rme28fdc88b5) for addition 2021-09-14 09:04:19,299 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Getting capabilities from Roomba 2021-09-14 09:04:19,299 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Capabilities for Roomba: Position: True, CarpetBoost: False, BinFullDetection: False 2021-09-14 09:04:19,300 Thread-3 polyinterface INFO roomba-poly:_addRoombaNodesFromQueue: Adding Series 900 Roomba: Roomba (rme28fdc88b5) 2021-09-14 09:04:19,304 Thread-3 polyinterface INFO polyinterface:addNode: Adding node Roomba(rme28fdc88b5) 2021-09-14 09:05:34,939 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-09-14 09:05:35,660 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-09-14 09:05:35,662 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-09-14 09:05:35,818 MainThread py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:32: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working 2021-09-14 09:05:35,818 MainThread py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:32: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working 2021-09-14 09:05:35,912 MainThread polyinterface DEBUG polyinterface:write: CV or numpy module not found, falling back to PIL 2021-09-14 09:05:35,915 MainThread polyinterface DEBUG polyinterface:write: PIL module not found, maps are disabled 2021-09-14 09:05:35,919 MainThread py.warnings WARNING warnings:_showwarnmsg: ./roomba-poly.py:15: ResourceWarning: unclosed file <_io.TextIOWrapper name='server.json' mode='r' encoding='UTF-8'> 2021-09-14 09:05:35,919 MainThread py.warnings WARNING warnings:_showwarnmsg: ./roomba-poly.py:15: ResourceWarning: unclosed file <_io.TextIOWrapper name='server.json' mode='r' encoding='UTF-8'> 2021-09-14 09:05:35,944 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.1.1', 'igb0')}, 2: [('192.168.1.1', 'igb0', True)]} 2021-09-14 09:05:35,945 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.1.1', 'igb0') 2021-09-14 09:05:35,946 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.1.178', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}] 2021-09-14 09:05:35,947 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.1.178', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2021-09-14 09:05:35,967 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-09-14 09:05:36,344 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-09-14 09:05:36,346 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/15 - MID: 1 Result: 0 2021-09-14 09:05:36,347 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-09-14 09:05:36,348 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-09-14 09:05:36,460 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-09-14 09:05:36,534 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-09-14 09:05:37,359 NodeServer polyinterface INFO roomba-poly:start: Starting Roomba Polyglot v2 NodeServer version 1.1.4 2021-09-14 09:05:37,360 NodeServer polyinterface DEBUG roomba-poly:discover: Beginning Discovery on Roomba Bridge 2021-09-14 09:05:37,362 NodeServer polyinterface DEBUG roomba-poly:discover: Connecting to Roomba 2021-09-14 09:05:37,369 NodeServer py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:340: DeprecationWarning: The 'warn' method is deprecated, use 'warning' instead 2021-09-14 09:05:37,369 NodeServer py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py:340: DeprecationWarning: The 'warn' method is deprecated, use 'warning' instead 2021-09-14 09:05:37,371 NodeServer roomba.__main__ WARNING roomba:setup_client: TLS Setting failed - trying 1.3 version 2021-09-14 09:05:37,768 NodeServer polyinterface INFO roomba-poly:discover: 1 Roomba's identified in configuration 2021-09-14 09:05:37,771 NodeServer polyinterface DEBUG roomba-poly:_startRoombaConnectionDelayTimer: Starting roomba connection delay timer for 5 seconds 2021-09-14 09:05:42,777 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Attempting to add 1 roombas that have connected 2021-09-14 09:05:42,779 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Processing Roomba (rme28fdc88b5) for addition 2021-09-14 09:05:42,779 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Getting capabilities from Roomba 2021-09-14 09:05:42,780 Thread-3 polyinterface DEBUG roomba-poly:_addRoombaNodesFromQueue: Capabilities for Roomba: Position: True, CarpetBoost: False, BinFullDetection: False 2021-09-14 09:05:42,781 Thread-3 polyinterface INFO roomba-poly:_addRoombaNodesFromQueue: Adding Series 900 Roomba: Roomba (rme28fdc88b5) 2021-09-14 09:05:42,784 Thread-3 polyinterface INFO polyinterface:addNode: Adding node Roomba(rme28fdc88b5) 2021-09-14 09:05:42,797 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV1: 1, uom: 25 2021-09-14 09:05:42,799 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ST: 0, uom: 78 2021-09-14 09:05:42,802 Controller polyinterface INFO roomba-poly:_updateBasicProperties: Roomba Connected: Roomba 2021-09-14 09:05:42,803 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - BATLVL: 100, uom: 51 2021-09-14 09:05:42,804 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV4: 82, uom: 51 2021-09-14 09:05:42,806 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV5: 629.0, uom: 20 2021-09-14 09:05:42,808 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV7: 0, uom: 2 2021-09-14 09:05:42,810 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:05:42,811 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:05:42,811 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:05:44,051 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:05:44,051 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:05:44,052 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:05:47,449 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:05:47,450 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:05:47,451 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:05:52,301 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:05:52,302 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:05:52,303 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:05:57,312 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:05:57,313 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:05:57,313 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:06:02,693 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:06:02,694 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:06:02,695 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:06:07,915 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:06:07,916 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:06:07,917 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' 2021-09-14 09:06:13,010 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating X Position on Roomba: 'pose' 2021-09-14 09:06:13,011 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Y Position on Roomba: 'pose' 2021-09-14 09:06:13,012 Controller polyinterface ERROR roomba-poly:_update900SeriesProperties: Error updating Theta Position on Roomba: 'pose' Link to comment Share on other sites More sharing options...
apostolakisl Posted September 14, 2021 Author Share Posted September 14, 2021 I just restarted Polisy this morning and the roomba node is already hung. Had to restart it again and it now has current data, but history is that it will freeze again very shortly. Also, isn't populating all the fields. Even after query. Link to comment Share on other sites More sharing options...
apostolakisl Posted September 14, 2021 Author Share Posted September 14, 2021 It has frozen again. 3rd time today after being reset each time. It might be coincidence, but it seems to always be "returning to charge" when it stops communicating. It is currently "frozen" at the time of this screen shot. 2021-09-14 17:24:22,597 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -478, uom: 56 2021-09-14 17:24:22,599 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: -131, uom: 14 2021-09-14 17:24:37,633 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV4: 100, uom: 51 2021-09-14 17:24:37,636 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -71, uom: 56 2021-09-14 17:24:37,639 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -630, uom: 56 2021-09-14 17:24:37,642 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 157, uom: 14 2021-09-14 17:24:42,666 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -194, uom: 56 2021-09-14 17:24:42,668 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -550, uom: 56 2021-09-14 17:24:42,671 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 133, uom: 14 2021-09-14 17:24:47,693 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -212, uom: 56 2021-09-14 17:24:47,695 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -418, uom: 56 2021-09-14 17:24:47,699 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 83, uom: 14 2021-09-14 17:24:52,697 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV4: 82, uom: 51 2021-09-14 17:24:52,700 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -180, uom: 56 2021-09-14 17:24:52,702 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -277, uom: 56 2021-09-14 17:24:52,704 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 59, uom: 14 2021-09-14 17:24:57,732 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -104, uom: 56 2021-09-14 17:24:57,734 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -154, uom: 56 2021-09-14 17:24:57,738 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 43, uom: 14 2021-09-14 17:25:02,732 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -3, uom: 56 2021-09-14 17:25:02,734 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -50, uom: 56 2021-09-14 17:25:02,737 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 79, uom: 14 2021-09-14 17:25:07,745 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -73, uom: 56 2021-09-14 17:25:07,747 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 92, uom: 14 2021-09-14 17:25:12,752 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -22, uom: 56 2021-09-14 17:25:12,754 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -57, uom: 56 2021-09-14 17:25:12,757 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 161, uom: 14 2021-09-14 17:25:17,772 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -39, uom: 56 2021-09-14 17:25:17,774 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -44, uom: 56 2021-09-14 17:25:17,777 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 94, uom: 14 2021-09-14 17:25:22,773 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -31, uom: 56 2021-09-14 17:25:22,775 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -32, uom: 56 2021-09-14 17:25:22,778 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 47, uom: 14 2021-09-14 17:25:27,776 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: -13, uom: 56 2021-09-14 17:25:27,778 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: -15, uom: 56 2021-09-14 17:25:27,780 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 45, uom: 14 2021-09-14 17:25:32,705 Thread-2 polyinterface ERROR polyinterface:write: Exception in thread 2021-09-14 17:25:32,706 Thread-2 polyinterface ERROR polyinterface:write: Thread-2 2021-09-14 17:25:32,707 Thread-2 polyinterface ERROR polyinterface:write: : 2021-09-14 17:25:32,707 Thread-2 polyinterface ERROR polyinterface:write: Traceback (most recent call last): 2021-09-14 17:25:32,708 Thread-2 polyinterface ERROR polyinterface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2021-09-14 17:25:32,713 Thread-2 polyinterface ERROR polyinterface:write: self.run() 2021-09-14 17:25:32,713 Thread-2 polyinterface ERROR polyinterface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2021-09-14 17:25:32,717 Thread-2 polyinterface ERROR polyinterface:write: self._target(*self._args, **self._kwargs) 2021-09-14 17:25:32,717 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3452, in _thread_main 2021-09-14 17:25:32,730 Thread-2 polyinterface ERROR polyinterface:write: self.loop_forever(retry_first_connection=True) 2021-09-14 17:25:32,731 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1779, in loop_forever 2021-09-14 17:25:32,737 Thread-2 polyinterface ERROR polyinterface:write: rc = self.loop(timeout, max_packets) 2021-09-14 17:25:32,738 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1181, in loop 2021-09-14 17:25:32,743 Thread-2 polyinterface ERROR polyinterface:write: rc = self.loop_read(max_packets) 2021-09-14 17:25:32,743 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1572, in loop_read 2021-09-14 17:25:32,749 Thread-2 polyinterface ERROR polyinterface:write: rc = self._packet_read() 2021-09-14 17:25:32,750 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 2310, in _packet_read 2021-09-14 17:25:32,757 Thread-2 polyinterface ERROR polyinterface:write: rc = self._packet_handle() 2021-09-14 17:25:32,758 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 2936, in _packet_handle 2021-09-14 17:25:32,768 Thread-2 polyinterface ERROR polyinterface:write: return self._handle_publish() 2021-09-14 17:25:32,768 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3216, in _handle_publish 2021-09-14 17:25:32,779 Thread-2 polyinterface ERROR polyinterface:write: self._handle_on_message(message) 2021-09-14 17:25:32,782 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV9: 4, uom: 56 2021-09-14 17:25:32,782 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3444, in _handle_on_message 2021-09-14 17:25:32,785 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - GV10: 2, uom: 56 2021-09-14 17:25:32,787 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver rme28fdc88b5 - ROTATE: 47, uom: 14 2021-09-14 17:25:32,802 Thread-2 polyinterface ERROR polyinterface:write: self.on_message(self, self._userdata, message) 2021-09-14 17:25:32,804 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py", line 459, in on_message 2021-09-14 17:25:32,807 Thread-2 polyinterface ERROR polyinterface:write: self.decode_topics(json_data) 2021-09-14 17:25:32,808 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py", line 713, in decode_topics 2021-09-14 17:25:32,811 Thread-2 polyinterface ERROR polyinterface:write: self.update_state_machine() 2021-09-14 17:25:32,812 Thread-2 polyinterface ERROR polyinterface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/roomba/roomba.py", line 820, in update_state_machine 2021-09-14 17:25:32,816 Thread-2 polyinterface ERROR polyinterface:write: self.current_state = self.states[self.cleanMissionStatus_phase] 2021-09-14 17:25:32,817 Thread-2 polyinterface ERROR polyinterface:write: KeyError 2021-09-14 17:25:32,818 Thread-2 polyinterface ERROR polyinterface:write: : 2021-09-14 17:25:32,818 Thread-2 polyinterface ERROR polyinterface:write: 'evac' Link to comment Share on other sites More sharing options...
fahrer16 Posted September 15, 2021 Share Posted September 15, 2021 It looks like it's related to a feature on some of the fancier roombas that empty themselves. It looks like the repo that reverse engineered the roomba protocol has a fix but there have been quite a few changes and I'll have to incorporate and test it out at some point to account for any necessary updates in the node server. Link to comment Share on other sites More sharing options...
apostolakisl Posted September 15, 2021 Author Share Posted September 15, 2021 1 hour ago, fahrer16 said: It looks like it's related to a feature on some of the fancier roombas that empty themselves. It looks like the repo that reverse engineered the roomba protocol has a fix but there have been quite a few changes and I'll have to incorporate and test it out at some point to account for any necessary updates in the node server. Awesome, thanks. Perhaps that is why it seems to drop out when it is returning to base. Link to comment Share on other sites More sharing options...
apostolakisl Posted October 20, 2021 Author Share Posted October 20, 2021 @fahrer16 Any update on this? Thanks. Link to comment Share on other sites More sharing options...
fahrer16 Posted October 21, 2021 Share Posted October 21, 2021 On 10/20/2021 at 1:57 PM, apostolakisl said: @fahrer16 Any update on this? Thanks. Thanks for the reminder, I've been really busy at work... ? Link to comment Share on other sites More sharing options...
apostolakisl Posted December 3, 2021 Author Share Posted December 3, 2021 @fahrer16 Just checking in again on this. Link to comment Share on other sites More sharing options...
fahrer16 Posted December 4, 2021 Share Posted December 4, 2021 @apostolakisl, I just took a look at updating to use the newest version of the Roomba python library and there have been quite a few changes since the node server was written; threading was added, which adds a decent amount of complexity trying to use the library directly. There'd be much more work required than I anticipated. I don't actually use this node server myself anymore, so between work and life I'm not sure when or if I'll have time to invest into a rewrite. If anyone is interested in taking over development, that might be the quickest path to this node server getting a refresh. Link to comment Share on other sites More sharing options...
bpwwer Posted December 4, 2021 Share Posted December 4, 2021 3 hours ago, fahrer16 said: I don't actually use this node server myself anymore, so between work and life I'm not sure when or if I'll have time to invest into a rewrite. If anyone is interested in taking over development, that might be the quickest path to this node server getting a refresh. @fahrer16I did a port of this node server to PG3 and can publish it to the PG3 store if you're ok with that. I don't remember if I used an updated version of the library or not when I did this, it was a couple of months back. But since I do have a Roomba, it seemed to work after the port. Link to comment Share on other sites More sharing options...
fahrer16 Posted December 4, 2021 Share Posted December 4, 2021 @bpwwer, sounds good, thanks! The existing copy still works fine for my 980 and would work for similar or more basic models (as long as iRobot doesn't introduce a breaking change in their proprietary protocol) but it isn't updated to work reliably with the newer Roombas that have come out since. The node server uses a library (https://github.com/NickWaterton/Roomba980-Python) that I forked a copy of a while back so that changes published to that repo wouldn't break the node server. I tested the newest version of that library with the node server offline and the node server would need a decent re-work to be able to use the newer library. Link to comment Share on other sites More sharing options...
bpwwer Posted December 5, 2021 Share Posted December 5, 2021 1 hour ago, fahrer16 said: @bpwwer, sounds good, thanks! The existing copy still works fine for my 980 and would work for similar or more basic models (as long as iRobot doesn't introduce a breaking change in their proprietary protocol) but it isn't updated to work reliably with the newer Roombas that have come out since. The node server uses a library (https://github.com/NickWaterton/Roomba980-Python) that I forked a copy of a while back so that changes published to that repo wouldn't break the node server. I tested the newest version of that library with the node server offline and the node server would need a decent re-work to be able to use the newer library. I guess I didn't look into using a newer version of the library so it's till pointing at your forked copy. For PG3, it probably makes sense to move to the latest version even if it is more work. Oh well, what's one more task for the task list Link to comment Share on other sites More sharing options...
