I apologize for the vague title and the sideways video (not sure why it came out that way but you can see what's going on)
The SWL stopped working so I air gapped it and started doing this.
Is this the SWL saying 'let me die'?
Andrew
Posted (edited)
Did you try Factory Reset?   Airgap again, wait 10-15 seconds.. push the airgap/set switch all the way in and HOLD IT IN until the long beep STOPS.
If that restores local functions, go to the ISY and right click the device and pick "restore device".
Edited by MrBill
I have tried that. It’s an older SWL and it doesn’t beep when I hold the button in for a long time. So I just hold it in for 15 seconds and let go. It now seems to be nonfunctional so that answers my question I’m assuming.
seems to have died....
BTW... I had a bad switch once that effected the way other things, specifically made things not work..... (referring to your other thread)
Replacement ordered.
Before I replace it I will try to sort out the yard light issue. Just in the last ditch effort that the yard light is affecting that one device
I meant it the other way around.... that one device might be affecting that the yard light.  Try air gapping the bad device so that it's un-powered, then see if the yard light works better.   the bad device maybe generating noise.
      37.1k
      371.6k
