40 minutes ago, Techman said:
What is the ID (xx.xx.xx) of the device that wouldn't install?
If other 2477S installed correctly then you system and ISY firmware are working correctly
38.65.8F
I think you didn't read the release notes when you upgraded from 4.X.X to 5.3.X. The problems you've had are perfectly understandable and to be expected. Fortunately they are all documented.
I think you better start reconfiguring all the devices and programs. From then on, errors will be corrected.
I had the same problem when version 5.0.X was released.
Edited by almron
