IO module does not accept Trigger Reverse
One of my IO modules does not accept "Trigger Reverse" anymore. It suddenly lost this setting (a lot of power outages lately).
When I check "Trigger Reverse," the system shows Busy for a while and the check mark remains on when finished. But when I click Querry, it's gone again.
The module is working well but the light on the 8-button panels is now reverse.
Anything I can try (beside buying a new one :-)
You may want to run the Event Viewer in Level 3. To see if the messages show anything.
Since the I/OLinc is power  line only. You may want to try in a different location and  branch circuit as a test.
Sorry it took me so long, Brian, I was travelling.
Long story short, I could not make it work, so I replaced the unit completely.
Thanks for your suggestions, I did appreciate them.
RV
