Any replacement for the Insteon I/O Linc?
Hello,
Sorry to break in with somewhat of a tangent, but my question is related to Insteon replacements.
Does any one have a replacement for the Insteon I/O Linc?  I've tried several possible sources but only E-Bay seems to have some used ones.
I don't need all the functions.  I just need a device that will tell my ISY if a 5V supply is on or not.
Thanks for any help.
Are you putting the +5 volts DC into the Sensor Input?
It has its own internal 5 volt sensing supply signal and is designed to have a dry contact on the sensor input. Though 5 volts probably would not damage it
The retail #2822-222 is a 2450 I/OLinc. Sold by retail vendors. Though you may not have much luck finding them either.
Edited by Brian H
