UD Mobile (iOS) favorites item not show 3 dots
Wiki says...
"because we have a Display Node there is a menu (three dots) which will open the Node's Dashboard".
Has this changed?  I cannot get those 3 dots to appear.
You are correct on both assumptions Sir.  However, from the Wiki it looks like it's supposed to be there for Type Node so you can shortcut to the dashboard of a device or scene as well.  I don't see it on those Favorite items either.
Hi @theitprofessor,
Thanks for confirming.
I'll try to update the Wiki with more detailed information.  Favorites of Type Nodes will automatically open the node dashboard, unless the node supports toggle.  If the node supports toggle pressing the (top) icon will toggle the node, pressing the (bottom) name will open the node dashboard.
Favorites of Type Command and of Type Folder with a Display Node should show the menu link to the node dashboard.  Favorites of Type Folder with a display node which allows toggle will toggle when the top icon is pressed and open the folder when the (bottom) name is pressed.
There are a few additional options on Android and we have a few additional Favorite Types coming in the future which will allow this to be more customizable.
Edit: Menu issue fixed in version 0.6.4
