Web Server Problems
I have a program on my ISY994 that runs once a day and saves a variable to a file.  I used the @webpage:/mydir/status.htm command to create the file and the @webpage:@append:/mydir/status.htm command to update the file.  These are in a Customizations that’s called using Send Notification.
When I moved these programs to ISY on Polisy, they are not working.  The create command seems to run but I don’t see the file on the Configuration | Networking | Web Server page.  I was able to copy a file from the computer side to the ISY side.  If I try to open the file, I get a ./FILES/FILES/USER/WEB/STATUS.HTM not found error.  If I change the url from //192.168.1.140:8443/FILES/USER/WEB/STATUS.HTM to //192.168.1.140:8443/USER/WEB/STATUS.HTM I can open the file.  If I use right mouse New Folder or Delete, I get an error message as shown in the screen shot.  The directory tree in Polisy ISY has an extra period that is not in the ISY994.  Anyone doing something similar?
