Help with ssh login to polisy from an imac
I would like to install PG3 on my polisy. I have seen the post on how to do this, but can't seem to login via ssh anymore. I am using the terminal window. I did it one time successfully. When I try now, I see the prompt from the policy followed by an icon that looks like a key. If I enter the password it rejects it. After 3 times I get permission denied message. See the login session below. I have looked in my apple keychain and see a polisy certificate. I tried deleting it but it made no difference except I could not login to my polisy via Safari. I know nothing about certificates etc so am at a loss as what to do. Can someone on a MAC suggest what to do next. All polisy updates are installed.
When you do the ssh from the mac, try
ssh -l admin 10.0.1.164
That's an ell, not one. Without the '-l admin' it's trying to log you in with a steve1 account which doesn't exist on the Polisy.
THANK YOU very much for the info and the quick reply.
That did the trick. PG3 is up and running and connected to my Polisy.
Steve
  • 3 months later...
@bpwwerI'm attempting to log into a polisy with a mac and I'm getting this error.
SSH protocol v.1 is no longer supported
This is what I'm entering in the command line.
ssh -1 admin 192.168.1.1.21
Thank you!
Thank you!
he's trying to tell you to use the letter lowercase L, not a 1....
ssh -l admin 192.168.1.1.21
Thank you @MrBill
I've successfully made the ssh connection. Now when attempting to run sudo pkg upgrade or sudo pkg install pg3 I get this message "process with pid 23274 still holds the lock"and pg3 is not installing. What's causing me to get this message?
Thank you!
