Add stored GPM "total Flow" for each circuit to zone info
Hi @glarsen
Just following up on a post you made in my other topic, on detecting leaks using the rain machine  and the flume node servers.
I have both of these apps running on my Polisy using the PG3 version. I am successfully pulling the current flow from the flume side.
I was wondering if you thought any more about adding the GPM flow rate by circuit to the Rainmachine side.
It is the value called "total flow" that I input when defining zones. It is the last piece of info I need to get this up and running.
My goal is, when I detect a circuit running, to take this value and compare it with the actual data ( after a startup delay ), that I am getting from flume. If I see consumption higher than (expected GPM from total flow plus some margin) to flag an error.
I would really appreciate it you could add this.
Steve
Edited by stevehoyt
it's a little less trivial than I first thought.  I will work on it in the next few weeks.  It may only be available in the PG3 version, depending on how much work is involved.
Thank you.
I have already upgraded to the PG3 Rainmachine version, so thats fine by me.
PS
as an aside when the PG3 work slows down with you @glarsen and @Jimbo
I have already mentioned to Jimbo that I would like to discuss a possible new nodeserver.
It could leverage the work done on  your 2 node servers capabilities, to create a new one that would simplify what I am trying to do.
Perhaps the merged one could just set a new value when actual usage exceeded expected, with adjustable parameters....
Hopefully you two could benefit from  your work to market a new one
Thanks again
Steve
Edited by stevehoyt
@glarsen
Hi
Just took a look at my rain machine info and it appears to have changed to cfm.
I believe we discussed that cfm  times 7.48 will give me what I need.
Is cfm going to be the final unit of measure or will it be gpm as was previously available.
Steve
see config info below
Edited by stevehoyt
add question about cfm
