Last Update time Format, is transmit power available , and chip temp
Just curious about  3 things.
1) What is the format of the field  "last Update time" see below.
2) Is the current transmitting power level available to add to a tags info. I like keeping track of it to follow the levels my tags are using.
3) Should the chip temp be accurate... mine says 246.2
Steve
Sorry, I missed this post somehow, just released a slew of fixes with version 3.0.14.
1) UNIX Epoch time.  Hopefully someday Admin Console can show the actual date.
2) Yes, it seems to be.  You can set logging mode to debug, then query a tag and when the tag responds you will see it 'txpwr': 159.  But, this will have the same issue as signaldBm, it is only updated on a query, it will not update as it changes.  Create an issue here if you can and you still want it https://github.com/UniversalDevicesInc-PG3/udi-wirelesstag-poly/issues
3) Sorry, I don't have a probe so I can't check, but if you do a Download Log Package and PM that to me I'll take a look.  I created an issue to track https://github.com/UniversalDevicesInc-PG3/udi-wirelesstag-poly/issues/48
