store variable values?
When you store variable value also set it's initialization value to the same.
Edited by JAbraham
Thank you,
I looked for something like that when I was writing a program but did not see it. Can you tell me how i would do that?
Leak.Kitchen.OK - [ID 0133][Parent 00CD]
        'Kitchen / Kitch.LD.dry / Kitch.LD.heartbeat' is switched On
     Or 'Kitchen / Kitch.LD.dry / Kitch.LD.heartbeat' is switched Off
        $sLeak.Kitchen Init To $cLEAK.DRY        <---------- *****************
        $sLeak.Kitchen  = $cLEAK.DRY
        Wait  25 hours
        Run Program 'Leak.Kitchen.OK' (Else Path)
        $sLeak.LowBatt.room Init To $cROOM.KITCHEN  <-------------- ***************
        $sLeak.LowBatt.room  = $cROOM.KITCHEN
        $sLeak.Kitchen Init To $cLEAK.LOWBATT       <--------------------- *************
        $sLeak.Kitchen  = $cLEAK.LOWBATT
        Wait  23 hours
        Run Program 'Leak.Kitchen.OK' (Then Path)
'Init to' is at the bottom of the arithmetic operator pulldown list
New Program - [ID 0009][Parent 0001]
        Time is  9:00:00AM
        $s.Test += 1
        $s.Test Init To $s.Test
Where you program the += change that to Init To.
Jeff
Edited by JAbraham
        Wait  25 hours
        Wait  23 hours
        Time is  9:00:00AM
        $s.Test += 1
Jeff
Thank you!!
