Posted January 5, 201015 yr what does the program status indicate on the program tab in the isy 99i? it does not seem to correlate to whether it is running or not.
January 5, 201015 yr Program status shows whether the program executed the THEN part (True) or ELSE part (False) on its most recent run. As you observed, it has nothing to do with whether the program is currently running or not.
January 5, 201015 yr The Activity column indicates if a program is Running or Idle. Only programs with Wait actions can usually be observed as running. Without a wait the notice usually just flashes for an instant. Rand
