Flashing test
Is there an elegant way to get a particular device to flash for testing? I got it to work with a 2-program 'flip-flop', but it's a bit cumbersome.
Jim
Jim
This worked on Halloween (I think) until I tried to build another for an indoor scene and ran into the Repeat 0 times wall :shock: I should have used Copy, but I was playing around. I think I had a Schedule in the If.
       Repeat Every  0 seconds
          Set  Scene 'Outside Lights - Evening' On
          Wait  3 minutes
          Set  Scene 'Outside Lights - Midnight' On
          Wait  3 minutes
I didn't want to test that, so I wrote this, which will flash a light:
       Repeat Every  1 second
          Set 'Foyer' Fast On
          Wait  1 second
          Set 'Foyer' Fast Off
I also learned that if the Program is in a folder that is scheduled to run only on Halloween that it won't run, no matter how many times I push the button :o
Rand
Ok, that is simpler, I didn't realize the 'repeat' function is used that way.
Yes, the UDI guys have been working very hard on the Programs of the ISY and it shows, doesn't it 8)
I think most of the wait for v2.5 is coming down to the documentation.
Rand
