New IoP release makes it easier to share Network resources.
This release brings a big change that makes using the REST option for the Notification Nodeserver much easer:
The addition of:
- Network resources malformed when using URL encoding. Follow these instructions
${sys.node.#.name:url}  - URL encodes the resulting string
${sys.node.#.name:std} -  Does standard formatting (as done currently)
${sys.node.#.name} – Does default formatting (currently same as using “:std”)
Now allows to create a Notification where the subject contains any node or program name, so you can use this in the path:
/send?node=po_dev&monospace=1&device=2&Subject=node:${sys.node.#.name:url}+program:${sys.program.#.name:url}
Even when the program contains spaces or other characters that would cause problems.  Now one network resource can be used for multiple notifications with different subjects
- Jim
Edited by JimboAutomates
