Can't add spoken
When I attempt to add a new device I get the error: "HTTP error 400 : Device cannot be added to the spoken database"
Any thoughts?
jeff
OK I lied.  i can add back zwave switch.  It wasn't letting me earlier.  But I can't add any device that is from node server. It is a Kasa TP Link outlet that I am trying to add.
jeff
Edited by BamBamF16
Hi @BamBamF16,
Please first check with the node server developer to see if they can add a hint for the node(s) in question. If that is not an option you can try the "Device Hint Editor" from "Connectivity" in the "Select Tool..." drop down on ISY portal.  Be sure to select the "Help" button for detailed information.
It looks like it should be a category 0X04 and a subcategory of 0X02.  But I don't see how to turn that into the correct value and I don't want to mess it up.
If you need an alternate method:
Use a State variable for Alexa, set the on and off values, percentage is calculated automatically.  Then have a program monitor the State variable and set the "on" value to the same state variable
Variable Test - [ID 0084][Parent 000F]
        $State_6 is not -1
        Set 'Devices / Basement / Basement Computer Room Lights' On '$State_6 %'
You may want to set the variable init value to -1 to avoid the light being changed on reboot.
