Running polyglot on two different RPI's to one ISY994i
I am running Push node server and Ambientpoly on one RPI and the node servers show up on my ISY . As soon as I install Ambient weather on a second RPI I no longer see the two node servers from the first RPI on my ISY. I want the two weather polys on two different RPI for reliability purposes. What do I need to do to make this happen. I was running the Ambient weather on PGC but with that shutdown I have no redundancy.
Edited by tlightne
I run the same Node server (PiCamMonitor) on 3 different RPi's to 1 ISY without issue.  The other Nodes show up in other DashBoards as unmanaged.  So the Nodes disappear in the ISY?  What does the PolyGlot DashBoard show on each RPi?
On RPI #1 it shows AmbientPoly as Connected and Ambient weather as unmanaged which I would expect to see because I only have the AmbientPoly installed there and it is Slot 1 on my ISY. On RPI #2 I have the AmbientWeather installed in slot 3 and it shows as connected. This is where it get weird. I had to install AmbientPoly on RPI #2 in Slot 1 before any AmbientPoly Node server would show in my ISY. I went in to the Node server profile for AmbientPoly and changed the IP address to RPI #1 and stopped AmbientPoly on RPI#2 and both node servers update their respective data. If I uninstall AmbientPoly on RPI #2 it disappears from my ISY. So I have to keep it installed on both RPIs for all to work.
