NS quits working
I have a polisy running isy and hue Node server on pg2.  After migration from ISY, I have an issue where my hue lights in isy scenes will seem to quit working at times.  For example, i have an Insteon switchlinc that turns on an isy scene that includes a couple of lights on Insteon devices plus a a hue room scene (that has 3 hue lights in it).  When I turn on the switchlinc, only the non hue lights turn on.  The hue lights do continue to work using my echo or the hue app.  This is issue comes and goes.  It seems the isy loses connection to the hue bridge.  I have another switchlinc with a similar setup and the same thing happens.  When the problem is happening at one switchlinc it is also happening at the other.  Any ideas or suggestions as to what might be going on?
Update:  with a little more troubleshooting, I found a couple more things…if I want into ISY dashboard and the main tab if I tried to turn on or off any hue hue lights (via Node server connection), they would not respond.  I went into PG2 and did a restart polyglot, and now they work.  Somehow, polyglot (I only have hue Node server on polyglot) is losing its connection with ISY on a regular basis.
jasson
jasson
I have been having a similar issue with my Husqvarna mower node.
