asbril Posted September 2, 2022 Share Posted September 2, 2022 7 hours ago, jjc said: @asbril Does it still work for you in PG2? and are you running PG2 on a polisy? No, I moved entirely to IoP, which is limited to PG3. In the meantime I use Google Cast on Home Assistant, which works fine. For Home Assistant I use the RPi that I previously (pre-Polisy) used for Polyglot. Link to comment Share on other sites More sharing options...
btreinders Posted September 2, 2022 Share Posted September 2, 2022 (edited) 27 minutes ago, asbril said: No, I moved entirely to IoP, which is limited to PG3. In the meantime I use Google Cast on Home Assistant, which works fine. For Home Assistant I use the RPi that I previously (pre-Polisy) used for Polyglot. How is IoP limited to to PG3? I run both PG2 and PG3 with IoP just fine. Edited September 2, 2022 by btreinders Link to comment Share on other sites More sharing options...
asbril Posted September 2, 2022 Share Posted September 2, 2022 16 minutes ago, btreinders said: How is IoP limited to to PG3? I run both PG2 and PG3 with IoP just fine. I guess I was wrong. Sorry Link to comment Share on other sites More sharing options...
btreinders Posted September 2, 2022 Share Posted September 2, 2022 Just now, asbril said: I guess I was wrong. Sorry No worries, I just wanted to make sure I wasn't missing something. Link to comment Share on other sites More sharing options...
