All Node Servers Disconnected After Updating PG3 to 3.0.56
All of my Node Servers are listed as disconnected.
Also - the Node server Store is empty. (It was before I did the update and was the reason I did the update.)
What do I do?
Hmmm. Just realized the PG2 Node server Store is empty as well. (I no longer have any PG2 Node Servers.)
Edited by Athlon
Sounds like a network/AWS issue.  Both versions get the store info from AWS. So either something (firewall) is blocking it, the network route is down for some reason or the AWS for your region is having issues.
@Athlon & @bpwwer Also not able to access PG2 store.
Last night I went to check for something in the PG2 store and my Bitdefender AV software flagged the URL. I created an exception and was still unable to access the PG2 store. I then checked PG3 and had the same AV issue, created another exception and was able to access the PG3 store with no issue. PG2 remains unavailable.
It's possible the URL I marked for exception in my AV software is wrong, but when I disable my AV software I am still unable to access the PG2 store. This leads me to believe it might be on the server side, but it's also possible it's on my PC side.
Whats weird is that I've never had to create an exception in my AV software for any of the UDI sites until last night.
Edited by kzboray
