Venstar T1800 Replacement to have more reliable thermostat control?
I've had some glitches with my T1800 Venstar thermostat which I use via the ISY994 and Mobilinc. It's not pleasant when I'm heading to the cabin 6 hours away and it's 50 degrees in there.
So I'm considering replacing it with something else, anyone had a positive experience with one? There are a couple Honeywell ones. There's the Nest which I figured I wouldn't want in the cabin setting since I'm there irregularly and have no need for it to learn my temperature habits, but it does have a manual mode I just learned. There are many others.
Mitch
I have used many different brands over the years...
ecobee, hands down! You will need a Node Server and that takes polyglot 2 or 3, with a RPi or polisy box.
