MyQ install Error
fresh install here and got an error message, it obiously will not start
2022-04-12 17:30:37,171 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-04-12 17:30:39,579 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.40 Starting...
2022-04-12 17:30:39,664 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-12 17:30:39,665 MainThread udi_interface      ERROR    udi_interface:write: File "./myqns.py", line 12, in <module>
2022-04-12 17:30:39,667 MainThread udi_interface      ERROR    udi_interface:write: import myqns
2022-04-12 17:30:39,668 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:5d:9c:cc_1/myqns/__init__.py", line 3, in <module>
2022-04-12 17:30:39,669 MainThread udi_interface      ERROR    udi_interface:write: from .nodes import Service, Gateway, MyQ_Device, GarageDoorOpener, Light, Lock
2022-04-12 17:30:39,670 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xxxxx_1/myqns/nodes.py", line 16, in <module>
2022-04-12 17:30:39,671 MainThread udi_interface      ERROR    udi_interface:write: from . import myqapi as api
2022-04-12 17:30:39,672 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xxxxx_1/myqns/myqapi.py", line 17, in <module>
2022-04-12 17:30:39,673 MainThread udi_interface      ERROR    udi_interface:write: import pkce
2022-04-12 17:30:39,673 MainThread udi_interface      ERROR    udi_interface:write: ModuleNotFoundError
2022-04-12 17:30:39,674 MainThread udi_interface      ERROR    udi_interface:write: :
2022-04-12 17:30:39,674 MainThread udi_interface      ERROR    udi_interface:write: No module named 'pkce'
Edited by Rootdet
sent you message
Edited by Rootdet
A new update was rolled out after sharing logs with Goose66. Mine works great now.
