Trouble with using an output as a controller in a scene
I'm attempting to use an output as a controller in a scene, and it seems that it has only implemented half of the link in the scene.
I created a scene, added 1 insteon SL as a responder, and added 1 Elk Output as a controller:
However, it appears that it does create both controller and responder links on the Output:
What I'm trying to do is allow my Elk to trigger a scene via an Output -- is this a defect, or is this by design?
Thanks for the quick response.
Back in the early days of Elk implications, is was pretty common to create phantom outputs to be used to trigger events. This is a great way to integrate elk tasks.
This did work with the Elk Module. I just discovered it when switching to IOP.
Great job on the node server, you managed to implement many more features of the Elk protocol than the module had!
Sent from my SM-T727A using Tapatalk
Yep, I'll go with the work-around for now.
FYI -- there was a perl module written 10-15 years ago that had worked out the logic for most of the elk RS-232 message protocol.  I picked that up 7-8 years ago to update it to include new message types, but have not maintained it for at least 5 years now.
I only mention it because when I was done with it, I had pretty much worked out all of the logic except for the audio devices (didn't really see how that would be useful).  I really don't think that Elk has updated the protocol since, so it is likely still a fairly comprehensive perl implementation of the RS-232.  I was mainly using it for logging, but had also added some code so that it would update an ISY  state variable whenever a temperature device sent an update message.  I think I may have also been logging user codes as well
If you are interested, I can probably find the perl code -- it may serve as a useful reference.
  • 4 weeks later...
I've had to turn off all my scenes that use an elk output as a trigger. It seems they randomly reset/go on-off audit triggers my scene which in this case shuts down the whole house.
Can you define random? Put log in Debug and when it happens download log and PM it to me. I would test but on vacation and won't be home for another couple weeks.
Sent from my Pixel 6 Pro using Tapatalk
So the last 2 nights, at or around 4am the ELK Node server does a query and does the same thing it would do when it starts up.  Just like when it starts up, the variable is set to Off and then On.  Setting to Off activate my test program that notifies me when it goes off.  I also have a program to tell me when it is set to On.  Even though when I go to look at variable it shows on, I only get the notification when it is set off.
It looks like it is initializing the value.  Below is when this starts (prior to that it is just doing it's polling thing) and then specifically the lines specific to the variable.
START
2022-05-24 04:03:18,905 Command    udi_interface      INFO     Controller:query: ELK Controller:
2022-05-24 04:03:18,906 Command    udi_interface      DEBUG    Controller:check_params: ELK Controller: host=XXXXXXXXXXXXXXX
2022-05-24 04:03:18,907 Command    udi_interface      DEBUG    Controller:check_params: exit: config_st=True
2022-05-24 04:03:18,907 Command    udi_interface.node INFO     node:reportDrivers: Updating All Drivers to ISY for ELK Controller(controller)
2022-05-24 04:03:18,908 Command    udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'address': 'controller', 'driver': 'GV1', 'value': 1, 'uom': 25}, {'address': 'controller', 'driver': 'ST', 'value': '1', 'uom': 25}]}
2022-05-24 04:03:19,105 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message query
2022-05-24 04:03:19,107 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING query
2022-05-24 04:03:19,107 Command    udi_interface      INFO     BaseNode:query: area_1:1 - Main House:
BUNCH OF STUFF QUERYING EVERY AREA AND ZONE UNTIL IT GETS TO OUTPUTS
OUTPUT VARIABLE
2022-05-24 04:03:22,454 Command    udi_interface      DEBUG    Output:set_drivers: House On: force=False reportCmd=True
2022-05-24 04:03:22,455 Command    udi_interface      INFO     Output:set_onoff: House On: val=None force=False reportCmd=True
2022-05-24 04:03:22,456 Command    udi_interface      DEBUG    BaseNode:set_driver: House On: ST,100 default=0 force=False,report=True
2022-05-24 04:03:22,456 Command    udi_interface      DEBUG    Output:set_onoff: House On: Send DON
2022-05-24 04:03:22,457 Command    udi_interface.interface DEBUG    interface:send: PUBLISHING {'command': [{'address': 'output_63', 'cmd': 'DON'}]}
2022-05-24 04:03:22,459 Command    udi_interface.node INFO     node:reportDrivers: Updating All Drivers to ISY for House On(output_63)
2022-05-24 04:03:22,459 Command    udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'address': 'output_63', 'driver': 'ST', 'value': 100, 'uom': 78}, {'address': 'output_63', 'driver': 'TIME', 'value': '0', 'uom': 58}]}
2022-05-24 04:03:22,721 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message query
2022-05-24 04:03:22,722 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING query
START
OUTPUT VARIABLE
Thanks, that was my suspicion, just when you said random I wasn't sure. It should set status during nightly query, but not send DON/DOF I will fix that when I return home.
