BlueIris on PG3 - cameras not present in AC
I'm posting this here in the PG2 BlueIris topic, because there is no BlueIris topic for PG3. I have installed Blue Iris under PG3 3.0.59. While the Blue Iris Node server is present in the AC, the cameras are not present. (I am running IoP 5.4.3) I am able to successfully change the blue iris profile, so I know the node server is communicating with the Blue Iris server. I've attached the log file package to this post.
BlueIris_4-20-2022_94453_AM.zip
3 minutes ago, bpwwer said:
I think I see the problem.  Try refreshing the store list to make sure it shows version 2.0.1 and then restart the node server
That fixed it, cameras are now present in the AC, thanks!
I just switched over to the PG3 version.
All is well except for one minor item. The Controller in the AC shows Node server Online as "1" instead of "True".
Is showing correctly in programs though: image.png.268ee20abc66f1d61c43cd887d2872b1.png
All I have left on PG2 are AVRemote, Ping, and Virtual (switches).
1 hour ago, bpwwer said:
Might be more correct in version 2.0.2
Shows "Connected" now.
