Error setting up fan, and a question
First, this is what I get when I put in the configuration information.  I've sanitized MAC and IP, obviously
022-04-21 14:11:30,003 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.40 Starting...
2022-04-21 14:11:30,255 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.0.56  [ISY: 5.3.0, Slot: 4]
2022-04-21 14:11:30,257 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '192.168.xx.xx', 'netmask': '255.255.255.0', 'broadcast': '192.168.20.255'}
2022-04-21 14:11:30,259 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:1888
2022-04-21 14:11:30,268 MainThread udi_interface.interface WARNING  interface:db_getNodeDrivers: controller not found in database.
2022-04-21 14:11:30,269 MainThread udi_interface.interface WARNING  interface:send: MQTT Send waiting on connection :: {'config': {'version': '3.1.6'}}
2022-04-21 14:11:30,316 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2022-04-21 14:11:30,318 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:52:bf:7c_4 -  MID: 1 Result: 0
2022-04-21 14:11:30,334 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,)
2022-04-21 14:11:33,284 MainThread udi_interface.interface INFO     interface:addNode: Adding node DysonFan(controller) [None]
2022-04-21 14:11:34,918 Thread-4   udi_interface      ERROR    dysonfan:dysonConnect: Error connecting to 192.168.xx.xx, 'NoneType' object has no attribute 'connect'
2022-04-21 14:11:34,920 Thread-4   udi_interface      ERROR    udi_interface:write: Exception in thread
2022-04-21 14:11:34,921 Thread-4   udi_interface      ERROR    udi_interface:write: Thread-4
2022-04-21 14:11:34,921 Thread-4   udi_interface      ERROR    udi_interface:write: :
2022-04-21 14:11:34,922 Thread-4   udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-21 14:11:34,923 Thread-4   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
2022-04-21 14:11:34,927 Thread-4   udi_interface      ERROR    udi_interface:write: self.run()
2022-04-21 14:11:34,928 Thread-4   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run
2022-04-21 14:11:34,932 Thread-4   udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-04-21 14:11:34,933 Thread-4   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:52:bf:7c_4/nodes/dysonfan.py", line 71, in start
2022-04-21 14:11:34,934 Thread-4   udi_interface      ERROR    udi_interface:write: self.dysonConnect()
2022-04-21 14:11:34,935 Thread-4   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xx:xx:xx:xx:xx:xx_4/nodes/dysonfan.py", line 98, in dysonConnect
2022-04-21 14:11:34,936 Thread-4   udi_interface      ERROR    udi_interface:write: LOGGER.debug(f"Auto Mode is {self.dysonData.auto_mode}, Night Mode is {self.dysonData.night_mode}")
2022-04-21 14:11:34,937 Thread-4   udi_interface      ERROR    udi_interface:write: AttributeError
2022-04-21 14:11:34,938 Thread-4   udi_interface      ERROR    udi_interface:write: :
2022-04-21 14:11:34,938 Thread-4   udi_interface      ERROR    udi_interface:write: 'NoneType' object has no attribute 'auto_mode'
2022-04-21 14:11:57,798 Thread-5   udi_interface      ERROR    dysonfan:dysonConnect: Error connecting to 192.168.xx.xx, 'NoneType' object has no attribute 'connect'
2022-04-21 14:11:57,800 Thread-5   udi_interface      ERROR    udi_interface:write: Exception in thread
2022-04-21 14:11:57,801 Thread-5   udi_interface      ERROR    udi_interface:write: Thread-5
2022-04-21 14:11:57,801 Thread-5   udi_interface      ERROR    udi_interface:write: :
2022-04-21 14:11:57,802 Thread-5   udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-21 14:11:57,803 Thread-5   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xx:xx:xx:xx:xx:xx_4/nodes/dysonfan.py", line 106, in poll
2022-04-21 14:11:57,805 Thread-5   udi_interface      ERROR    udi_interface:write: if self.dysonData.is_connected is False:
2022-04-21 14:11:57,806 Thread-5   udi_interface      ERROR    udi_interface:write: AttributeError
2022-04-21 14:11:57,806 Thread-5   udi_interface      ERROR    udi_interface:write: :
2022-04-21 14:11:57,807 Thread-5   udi_interface      ERROR    udi_interface:write: 'NoneType' object has no attribute 'is_connected'
2022-04-21 14:11:57,808 Thread-5   udi_interface      ERROR    udi_interface:write: During handling of the above exception, another exception occurred:
2022-04-21 14:11:57,808 Thread-5   udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-21 14:11:57,809 Thread-5   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
2022-04-21 14:11:57,813 Thread-5   udi_interface      ERROR    udi_interface:write: self.run()
2022-04-21 14:11:57,814 Thread-5   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run
2022-04-21 14:11:57,818 Thread-5   udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-04-21 14:11:57,819 Thread-5   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xx:xx:xx:xx:xx:xx_4/nodes/dysonfan.py", line 113, in poll
2022-04-21 14:11:57,821 Thread-5   udi_interface      ERROR    udi_interface:write: self.dysonConnect()
2022-04-21 14:11:57,822 Thread-5   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/xx:xx:xx:xx:xx:xx_4/nodes/dysonfan.py", line 98, in dysonConnect
2022-04-21 14:11:57,824 Thread-5   udi_interface      ERROR    udi_interface:write: LOGGER.debug(f"Auto Mode is {self.dysonData.auto_mode}, Night Mode is {self.dysonData.night_mode}")
2022-04-21 14:11:57,825 Thread-5   udi_interface      ERROR    udi_interface:write: AttributeError
2022-04-21 14:11:57,825 Thread-5   udi_interface      ERROR    udi_interface:write: :
2022-04-21 14:11:57,826 Thread-5   udi_interface      ERROR    udi_interface:write: 'NoneType' object has no attribute 'auto_mode'
Second question, how can I put in multiple Dyson devices? :)
I think it's telling you that it wasn't succesful in connecting to your fan.  Perhaps you can turn on DEBUG in logging, and then restart the node server again.  You can PM the log to me instead if inserting in the public space.
Double check your configuration - make sure there are no leading or trailing spaces in any of the elements.  I know it's a bit tricky because of the Dyson API - acquiring that credential need to connect is a pain.
I believe you can run two copies of a node server on PG3; they would just be installed in separate slots.
