PG2 backup.
Anyone know if you can do a backup of PG2 from a raspberry pi and restore said backup onto the Polisy?  I am wanting to do this so I don’t have to reload and setup my node servers manually.
Jasson Lamb
Jasson Lamb
Guessing here a little, isn't it your programs you want backed up? If so, you should back up your ISY.
If you have to 'reconnect' to PG2 coming from a different server (Polisy instead of an RPi), just be sure to put each Node server on the same node. That's what I did and it worked fine.
I checked each program that looks at a node, and I had to make very few changes if I recall correctly.
