Wet State at Startup is WET until Changed
Tag type 32, Moisture Sensor has a Wet State parameter which I believe to be driver GV12. This driver only updates on a change so at restart it comes up as WET, whether it is or not. I discovered this when the power on Polisy was cycled, and then the node indicated WET. Well, this kicked off an ISY Program and started up a water pump.
Any ideas on how to circumvent this behavior? I prefer it would come up correctly indicating whether it was DRY or WET.
