Nodes not showing up in Polisy
kowaj
So my raspberry Pie crapped out and I am trying to rebuild Hue, Bond, and Ambient weather nodes.  I have Hue and Bond added but they are not populating in the Polisy.  I have rebooted multiple times and just not showing up.  Not sure what else to try.
I see the below in my Polyglot v3 log
29/2022, 11:03:41 [polyglot] info: Successful login by admin
4/29/2022, 11:03:41 [polyglot] info: MQTTS: polyglot_frontend-7b8FH authenticated successfully.
4/29/2022, 11:03:41 [polyglot] info: MQTTS: Client Connected:
4/29/2022, 11:03:41 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
4/29/2022, 11:04:39 [polyglot] error: MQTTS: clientError: polyglot_frontend-7b8FH write after end
4/29/2022, 11:04:39 [polyglot] info: MQTTS: Client Disconnected:
4/29/2022, 11:04:39 [polyglot] info: Successfully updated profile for User: admin
4/29/2022, 11:04:39 [polyglot] info: MQTTP: Frontend Websockets interface Disconnected.
4/29/2022, 11:04:45 [polyglot] info: Successful login by admin
4/29/2022, 11:04:45 [polyglot] info: MQTTS: polyglot_frontend-7b8FH authenticated successfully.
4/29/2022, 11:04:45 [polyglot] info: MQTTS: Client Connected:
4/29/2022, 11:04:45 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
4/29/2022, 11:05:08 [polyglot] info: Settings Saved Successfully.
4/29/2022, 11:05:08 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 192.168.86.51:80
4/29/2022, 11:05:09 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 192.168.86.51:80
4/29/2022, 11:05:09 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ECONNREFUSED 192.168.86.51:80
4/29/2022, 11:05:09 [polyglot] error: Get Version HTTP Error: RequestError: Error: connect ECONNREFUSED 192.168.86.51:80
4/29/2022, 11:05:09 [polyglot] error: ISY: Failed to get version.
Whatever is at 192.168.86.51:80 is refusing the connection.  Are you sure you PG3 properly configured with the ISY information?
.51 is my Polisy.  I also looked at the console and it showed using port 8443 for some reason.  Tried that and still not communicating.
      378.7k
