Need Help, Just updated Firmware on my ISY 994i Zw Pro from 4.9.0 to 5.3.4 and programs don't run.
When I go to Program summary get message "Not Implemented" When I got to programs detain I see under Activity-" Not Loaded for each program and under Status it says "Out of Memory" for each program.  It all worked great under 4.9.0 firmware.  What do I need to do? Can I go back to 4.9.0, if so where do I download it.
Thanks for any help.
Solved by Techman
What happens when you check Help > About?   Is the firmware version 5.3.4?
First try rebooting the ISY.
Did you follow the upgrade instructions?
Upgrading to this version may require a lot of manual intervention including verifying scenes, programs and program settings are correct.  In some cases it will be easier to rebuild your network.
4 hours ago, Chuck166 said:
Yes it is 5.3.4
What you're describing sounds like mismatched firmware and admin console... so I'm suprised they match.
the issue @Techman refers to is about the use of "adjust scene" use in a program.  that particular program statement won't update automatically and requires manual intervention.
4.9 is in this thread, if you want to try to go back.  I'm curious tho what's going on with your programs.
Thank you, that fixed my problem.  For some reason, lost a couple of devices and had to reinstall.  Everything works great now.
